I recently purchased two monitors on black friday and after getting them hooked up, my computer seems to be running much slower. My RAM/CPU seem to really be taxed from the upgrade and as I would like to utilize them I began looking into upgrading my RAM as I thought that would do the trick. After reading some articles I believe upgrading my RAM would only have a minor impact (correct me if I'm wrong) and I should focus on upgrading my CPU and/or GPU instead. I'm lost as to what parts are good/aren't good, incompatibilities, if I need a larger power supply, etc. My PC is stock other than I believe that it came Windows 7 and now runs Windows 10, so I'm sure a lot of things could use an upgrade, but realistically I'm on a $200-300 budget. I'll try to include the specs that are helpful, but if I leave something out, let me know and I'll update it ASAP.
Brand: HP - Compaq Pavilion p6-2003w
OS: 64Bit Windows 10
Processor: AMD E2-3200 APU with Radeon(tm) HD Graphics 2.40 GHz
Installed RAM: 4GB (3.49 usable)
Again, my budget is $200-300, but I would prefer to keep it in the low 200s. I appreciate any suggestions as they'll likely only improve my chances of a successful upgrade.
Thanks!
Thanks!
