need help with power supply that will fit a hp elite 8300 microtower case
IanN11
i need help figureing out what power supply i need to buy that can fit my hp elite 8300 convertible microtower. My current power supply is only 320w and i apparently need a better one so i can replace my amd radeon hd 6570 graphics card with a evga geforce gtx 750 ti card i got from a friend, according to said friend i can only replace the power supply with an hp one that can fit the case, if so how do i go about figuring out what power supply i need and where to find it, ive already tried searching online for what i need but i dont know how to go from just having the info on my current power supply to finding one that will fit.
also as aside question would my 320w power supply be enough to run the graphics card do i absolutely have to get a new one
GTX 750 Ti is 75W GPU and 300W range PSU should be enough for it.
Though, look if your GPU needs an external power connector from PSU or not. Some GTX 750 Ti GPUs need external power connector and some don't.
If the external power connector isn't needed then you're good. If it is needed, look if your current PSU has the required 6-pin PCI-E connector.
it does have a 6 pin connector port (or whatever you call it) but i dont know if its required to function or not but thanks for the quick reply
EDIT: my psu doesnt have a 6 pin connector so if it does require is it possible to use a sata to 6 pin adapter to power it?
thank you Aeacus and Sm0k for all the help,just got it installed and tested on a couple different games and its working great with the 2 sata to 6 pin adapter
