[SOLVED] need help with power supply
alexc24
Commendable
Apr 1, 2018
31
i currently have a corsair rm series power supply and i just want to know if i were to switch to one with higher wattage can i just simply switch the power supply without unplugging everything i would be using another corsair rm series power supply or would that cause an issue?
you have to be careful, if corsair switched OEM or 650w/750w were made by different manufacturer, the pinout could be different.
the safest way is always use the cable that it came with. and not mix match them unless they are the same model and revision.
From what I see its identical but just wanted to be sure before I did anything
I would ask Corsair.
