C clxcii Prominent Jun 27, 2017 2 0 510 Jun 27, 2017 #1 CABLES QUESTION. My friend is building first time PC. He has a Seasonic S12 II 520W and is planning on getting a GTX 970. - Will the Seasonic come with power cables to fit the 970 or will we have to purchase separately?
Solution MrN1ce9uy Jun 27, 2017 The Seasonic S12 II 520W has 1x 6+2-pin and 1x 6-pin PCIE connector. That should be enough for a GTX 970 as they usually require a single 6+2-pin.
MrN1ce9uy Judicious Aug 20, 2009 7,012 668 35,890 Jun 27, 2017 Solution #2 The Seasonic S12 II 520W has 1x 6+2-pin and 1x 6-pin PCIE connector. That should be enough for a GTX 970 as they usually require a single 6+2-pin. Upvote 0 Downvote Solution
K kaptainkuftic Honorable Jul 26, 2016 1,430 1 11,965 Jun 27, 2017 #3 Yes. The S12 II 520W comes with a PCIe 6 and a PCIe 6+2, and he'll need both. Just to be safe, what 970 is it? Upvote 0 Downvote
