Okay so I'm going to build a PC with the following specs, and I wondered what wattage would be required on a PSU for the following specs, allowing for OCing.
MSI RTX 2070 GAMING Z.
Intel Core i7-9700k@3.6GHz.
MSI MPG Z390 CARBON PRO.
Corsair H115i platinum.
Corsair Vengeance RGB PRO (2x8GB) 3200MHz. (May add up to 2x8 more in the future)
6 Corsair 120mm 1500RPM fans
Plus one or two Corsair M.2 NVMe PCI SSDs, and multiple HDDs.
it's pretty much all kitted with RGB lighting if that makes a difference.
I have a relatively good understanding of components, but no clue whatsoever about power consumption. Having looked at MSI's website, they tell me I'd need a 1000W PSU, which sounds pretty ridiculous to me.
Thanks a lot .
Thanks a lot .
