Need Help with Ram and PSU
wisewisdom
I have been looking around for a nice computer, and in the end have decided to build one myself. I will be using it for gaming and video editing. I don't know a lot so I tried researching a little and pretty much this is what I have gathered so far.
The things I would like to have:
NZXT Guardian 921 RB
i5 3570k CPU
Asus P8Z77-V - LGA 1155 Motherboard
Corsair Hydro Series H110 (If it fits in case, if not the Hydro Series H100i )
Gigabyte nVidia GeForce GTX 660 OC 2GB
2x 21.5inch Monitors
Western Digital 3TB Green 64MB SATA 3
Pioneer Blu-Ray Writer (BDR-208DBKS)
Windows 7 Premium 64bit
$1200 without Ram and GPU(Australian Prices)
Budget is $1400
Need help on what ram whether to use 8 or 16GB, decent PSU and if I should get a better GPU.
Is this decent for the price range? If not, what would you recommend for $1400.
Thanks
Green = energy saving and slowwwwww. For video, ya want the WD Black
for the MoBO get the ASUS P8Z77-V LK
I don't see the Corsair H series ... to noisy, no cooling advantage over air coolers at same noise level.
Id use 16GB (2 x 8GB) of at least DDR3-1600, CAS 9
Two 650 Ti Boosts beat the pants off a 680 for less money.
This was $1320 on April 30th on this side of the pond....be a bit more down under and ya cant get the newegg combo discounts.
Case - $210 - Corsair 500R White http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1278902
PSU - inc w/ above - Corsair HX850 http://www.newegg.com/Product/Product.aspx?Item=N82E16817207011
MoBo - $275 - ASUS P8Z77-V LK http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1270852
CPU - Included - Intel Core i5-3570k Ivy Bridge http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Cooler - $80 - Phanteks PH-TC14PE http://www.newegg.com/Product/Product.aspx?Item=N82E16835709001
TIM - $5 - Shin Etsu http://www.newegg.com/Product/Product.aspx?Item=N82E16835150080
GFX - $390 - MSI N670 PE 2GD5/OC http://www.newegg.com/Product/Product.aspx?Item=N82E16814127685
GFX - later - MSI N670 PE 2GD5/OC Same
SSD - $140 - Samsung 840 Pro http://www.newegg.com/Product/Product.aspx?Item=N82E16820147192
HD - $160 - WD Caviar Black 5 yr warranty 2 TB http://www.newegg.com/Product/Product.aspx?Item=N82E16822136792
DVD Writer - $60 - Asus Blue Ray Burner http://www.newegg.com/Product/Product.aspx?Item=N82E16827135252
