Need help with ram!!
xxironstealxx
Commendable
May 6, 2016
31
Hi, my computer is currently running on this type of ram
https://www.newegg.com/Product/Product.aspx?Item=9SIAGGN79S1004&cm_re=g.skill_sniper_series_1866-_-9SIAGGN79S1004-_-Product
The problem is that it is out of stock everywhere and the places that it is in stock, it is overprices asf. So, I am wondering is there any other ram brands you guys would recommend for putting in my pc that would be compatible and wouldn't mess up the ram speed when I add it. Also, I am looking for a 2x4 gb ram since that is what my pc is running on right now. (Want to run 4x4gb on my pc)
MERGED QUESTION
Question from xxironstealxx : "Need help upgrading ram!"
Would there be another ram type you would recommend ?
