Need help with RGB in pc
CreepyNinja
41
I am building a RGB pc and i never did it before (the RGB stuff). My basic question is: will it be posible to connect every RGB light in this pc and control it with 1 program?
this is the pc: https://pcpartpicker.com/list/M7JjpG
I will replace the fans from the cooler with the 3 pack. And i will be adding some led strips too. The 3 pack also comes with a lighting controller or something but i dont know how to use it.
And if it is possible (i guess it is) how do i connect those rgb features? I know there is a rgb header (even 4 on this mobo) but what do i connect where?
You can't control all your RGB from one single software since most brands have their own dedicated RGB LED control software. For example:
hardware: Corsair H150i Pro AIO - software: Corsair Link
hardware: MSI Z370 Gaming Pro Carbon AC - software: MSI Mystic Light Sync
hardware: G.Skill Trident Z RGB RAM - software: MSI Mystic Light Sync
hardware: MSI GTX 1080 Ti Gaming X 11G - software: MSI Gaming App
hardware: Corsair LL-series fans - software: Corsair Link
hardware: LED strips - software: MSI Mystic Light Sync (if you plug them to your MoBo RGB header)
hardware: LED strips - software: Corsair Link (if you plug them to Corsair Lightning Node Pro)
At this setup, you're looking towards 3 different programs if you want to control all...
At this setup, you're looking towards 3 different programs if you want to control all RGB LEDs in your build.
As far as connecting Corsair LL-series fans go, they come with a setup manual that you can read.
