I have a AORUS AX370 Gaming K5, I want to add a rgb strip but I don't know which one to get that is compatible. I'm not sure if addressable rgb strips are compatible with my board. Would be great to find one that works!
you know that answer for your question can be found in you mainboard manuals rite?
well, your board doesnt support addresable RGB, it has 1x RGB, and 1x RGBW connectors
so you can use either 2x RGB or 1x RGB + 1x RGBW
strip type is SMD 5050
so search for smd 5050 rgb/rgbw strips
Actually can you link me one that would connect perfectly. I don't want to mess up lol.
