Hello I need some help with item that is stuck in the right click menu a while I installed a copy of my encryption sort ware on windows 10
how ever when I right click on folder it gives the wrong shortcut taking you the place where you register I have tried uninstalling and even used revo uninstaller but that did not worked also tried a program called configure file menu tools but it did not show the item
how do I remove this item from the menu as it is very annoying it is in place where you right click in a folder
Windows 10
Version 21H1
the version of windows Iam using is
osbuild 19043.1526
Windows features experience pack 120.212.4170.0
Windows 10
Version 21H1
osbuild 19043.1526
