Need Help With ROG Z390-E
tunatuna302
Notable
Aug 9, 2018
279
I have the rog z390-e and nzxt h500. there is this cable with a 6 pin (4 empty) connector and 4 little 2x 1 pin and 2x 2 pin things all detached. first of all, the 1 pins say p+ and p- led the 2 pins say h.d.d led and pwr SW. what is this cable called? (it came in a plastic bag) and where do i plug both ends?
It's for your front panel header youre talking about little plastic thing right? You don't have to use it if you don't want to. Just plug cables from fron panel into motherboard each one in its place
well one end is a 6 pin thing and the other end is just like i said those 2 and 1 pin little power sw and hdd led and the other 1 pin ones what does it work for and what is it called?
I have been having the same problem but the end of the cable that is labeled with +p led and what not goes on the right side of the front panel (consult the manual, look for the motherboard layout it lists everything on it) but i dont know what the other 4/6 is for since its too short to connect to anything else and id need another cable
so for my situation, that cable came with a bag in my mobo. I was told those are front panel connectors but all my front panel buttons are working without problem. did your case have them handing in the back?
Package contents
Check your motherboard package for the following items.
Motherboard
Cables
Accessories
Application DVD Documentation Others
1 x
2 x 1 x 1 x 1 x
1 x
1 x 1 x 1 x 1 x 1 x 1 x 1 x 1 x 1 x 1 x
ROG STRIX Z390-E GAMING motherboard
2-in-1 SATA 6Gb/s cables
Thermal sensor cable
Extension cable for RGB strips (80cm)
Extension cable for Addressable LED strips (80cm)
so I believe, the cable that has the 1 and 2 pin connectors is one of the extension cables. once again, does your case have them hanging in the back?
Latest posts
