Question Need help with rx 580
Mar 9, 2025
6
6
15
So I bought a rx 580. View: https://imgur.com/a/JbBoQse
I googled whats on it (axrx 580 8gbd5-dm) and it shows me a powercolor mining edition which looks the same as mine. (With only dvi)
But on the gpuz program it says subvendor is msi View: https://imgur.com/a/L0TmzZA
Could it be because msi bios was flashed in it?
Also the gpu max uses 75w and performs the same fps and score as it is shown in the furmark website. Is that a good or a bad thing? Should I switch bios on it or leave it as is? If I should switch which bios should I switch to? I couldnt find one that is the same as mine.
View: https://imgur.com/a/1dZOH3r
Reactions: artk2219
You don't buy used GPU's from that era and to add you've found that it's a minig card, meaning it was subjected to immense stres, then when the mining craze died down or when mining farms were being raided by the police, the blokes there flashed the GPU VBIOS to something else and sold it off as a gaming GPU.
If I were you, I'd return the GPU and pick something up brand new and something that comes with warranty.
If the GPU can't be returned, I'd leave it as is and work with it till it conks out.
It's looks like a powercolor card that they've just flashed with an MSI bios. If it works fine, leave it as is. If it doesn't, flash it back to a regular powercolor rx580 bios, and reinstall that missing screw either way. Otherwise if it was cheap and it works you should be good.
Put the original BIOS on it and see what happens.
I
I think you are right. On the back of the gpu thhe sticker says axrx which if I google shows the powercolor card
Reactions: artk2219
Reactions: D3ni1222
