Need help with Ryzen 3 Compatibility
Alister02
Commendable
Jan 10, 2017
16
Hey, I was looking to upgrade my intel pc build into a ryzen 3, I need some help with the compatibility of some parts, since it's my first time building AMD.
The parts I need help with are:
Crucial® DDR4 8GB 2133MHz
M/B AMD A320M-C (AM4)
AMD® CPU Ryzen 3 1300X (AM4)
Are these parts compatible with eachoter?
I am looking to hook them up with:
- a GTX 750 ti sc (Which shouldnt be a problem if these parts are compatible)
- a Fractal Design 450W Integra M 80Plus Bronze
- a random ssd, which I know for sure is compatible with the motherboard.
*Disclamer*
Please dont recomend other parts that would make my build much cheaper and better, because where I live, it's very hard to get many of the parts, so I would like to stick to the parts I provided, unless they are not compatible. (If some of you insist, this is the only website where I am able to get parts from: www.pcfactory.cl )
Thanks guys.
Ryzen - DDR Maximum Frequency Support Table(For better DDR4 compatibility, it is recommended to follow the table below to install DDR4 modules.
Maximum DIMMA1 DIMMB1
DDR4-2667 SR -
DDR4-2667 DR -
DDR4-2667 SR SR
DDR4-2400 DR DR
SR:Single-rank DIMM, 1R x4 or 1R x8
DR:-Dual-rank DIMMs, 2R x4 or 2R x8
___________________________________
The A320 motherboards are your basic, no-frills AM4 motherboards.
B350 motherboards for a small price increase offer CPU overclocking which is unlocked on B350 motherboards, and compared to the bare-bones A320 boards, this chipset packs in support for an additional 10Gbps USB 3.1 port as well as two more PCIe lanes for cutting-edge SSDs like Samsung 960 Pro.
