Need help with Samurai character
Ice
258
Archived from groups: rec.games.computer.ultima.online (More info?)
Ok, where do I go from here? There is not enough
points to do this character right IMHO.
At this time I have her at;
Swords 110.3 can go to 115
Focus 100.4 can go to 110
Anatomy 100
Tactics 100
Bushido 91.7
Healing 87.0
Parrying 75.4
Chivalry 50.8 for travel
I would love to have resist, but where would I put it?
They have added skills, combined required skills but never
raised the skill limit.
Unlike Magic and Chivalry, Bushido and Necromancy has no
"travel/recall" ability, therefore you need an extra 50 or so points
to travel around.
Unlike Chivalry and Necromancy, Bushido has no healing ability, so
healing in a necessity. I know people have talked about Anatomy and
Tactics not being necessary, but I disagree, I can see a big
difference in damage with them at gm level or better.
Do I drop Parrying, and give myself 50 or so resist, or keep Parrying
at 50 or so, and finish off the swords, focus, healing and Bushido?
I can do some of that with charms.
I wonder what numb-nuts thought up this s&*% but did not think
of raising the skill point level. They just keep adding stuff without
changing the base. Crafts are just as bad now. A smith needs
mining to smelt, a miner needs tinkering to make shovels, now
a smith needs tailoring to repair or enhance the new fans, and
carpentry to make forges and anvils, and a tailor needs carpentry
to make add-on's along with tinkering and magic for pentagrams,
and other house add-on's, and music for music instruments.
We really need an 800 base, but I would take 750 if I could just
get it. They gave "vets" an extra 20 with AOS, but 20 does not
help much.
Ok, what do I give up? I need some advice here.
Ice
G
Guest
Guest
> Anatomy 100
> Tactics 100
> Bushido 91.7
> Healing 87.0
> Parrying 75.4
I would skip the healing. You can actually heal yourself with
Bushido-Confidence. And you have Chivalry which can also be used to heal.
I have a samuraj too, he works really well. He looks like this :
Sword: 103.5 , shall go to 110
Tactics 101.9 , shall go to 110
Parry 100 , locked
Anatomy 93 , shall go to 100
Focus 92,7 , shall go to 100
Bushido 87,2 , I might take this up to 120, havent decided yet
Chivalry 80 , locked
With this, I get no Magic resistance, but I can clean myself from some
curses and stuff with Chivalry , so it will have to do.
I heal with Confidence (Bushido) and Chivalry, and I use exclusively
Mana leech weapons. He's a real killer :) He can take down 2 Ogre Lords
simultaniously without too much trouble using a combo of Chivalry stuff
and Bushido tricks, and dont forget to Honor the monster :), and
Dragons are pretty easy too.
Hope this helps some anyway. Good luck.
/ZW
Ice
258
On Sat, 01 Jan 2005 13:19:47 +0100, ZoombyWoof
>> Anatomy 100
>> Tactics 100
>> Bushido 91.7
>> Healing 87.0
>> Parrying 75.4
I do not think I could give up the healing. The Bushido-Confidence is
not that good, and I would have to use valuable mana to use it, same
with the Chivalry healing. She only has 30 Int, 38 with charms. I
really like the high Str and Dex, so I want to save mana for moves.
My Paladin has no Parry, and I can not see her doing much worse
than the Samurai with 75.4. Has anyone tested this on the Test
shard?
>Parry 100 , locked
>/ZW
G
Guest
Guest
>>> Anatomy 100
>>> Tactics 100
>>> Bushido 91.7
>>> Healing 87.0
>>> Parrying 75.4
>shard?
I wouldn't give up Parry with a samurai. They get a big bonus for
using 2 handed weapons if they have parry right?
Could you drop focus down to 60 or 80 or do you really use that much
mana when you fight?
Reg LeCrisp - Atlantic
G
Guest
Guest
>>>Anatomy 100
>>>Tactics 100
>>>Bushido 91.7
>>>Healing 87.0
>>>Parrying 75.4
> shard?
I would not give up parry with a samuraj...and the thing with mana being
used for healing, is to only use mana leech weapons.
>>Parry 100 , locked
>>/ZW
G
Guest
Guest
> Anatomy 100
> Tactics 100
> Bushido 91.7
> Healing 87.0
> Parrying 75.4
> to travel around.
It's now possible to use a filled runebook without any skill in
Magery/Chivalry, so you could drop Chivalry if you have it only for that
reason.
Torsten
G
Guest
Guest
Anat and tacts add good hits to your weps.
80 healing may do the trick cuz with 100 anat your healing is is in + mode
do you need 50+ in chiv for travel, i though it was 30?
"Ice" <nobody@noplace.com> wrote in message
news:aapct0de8gl4tunfcg8da5m855ecfo5uvg@4ax.com...
> Anatomy 100
> Tactics 100
> Bushido 91.7
> Healing 87.0
> Parrying 75.4
> to travel around.
> help much.
> Ice
