Hello,
I'm getting a black magic intensity pro. According to Google & Amazon it fit's into a PCI 1x slot.
Now for the hard part. I have a Packard Bell stock computer and have they're own brand mother board and being a Novice PC Builder and don't know if they two sockets that are available are PCI 1x.
When I tock the side off , I noticed they're two sockets un used. One was a small one , the slot next to it which was the same size had my Wifi Card in it.
The next slot was a big one , the one next to it which was used had my GPU in it.
I have included some Pics as well.
http://s1204.photobucket.com/albums/bb419/irock971/
Problem 2
Ok , I've been doing my Homework and I read that for un compressed capture of 720P 59.94 FPS You need a write speed of around 130-150 Mb/s
So , I need to get a new drive. But when I took a look at the cables. The one read "Serial ATA" I have no idead what the means. The ones , I've been looking at are SATA II.
So , please can you take a look at the pics and help me out. Is the plug that I took a picture of Serial ATA?
Or , Could I get a USB 3.0 Card? Then buy an extrenal one and use the USB 3.0? Will My Mobo support the Bandwith.
Amazon link to Black Magic: http://www.amazon.co.uk/gp/product/B001CN9GEA/ref=s9_simh_gw_p147_d0_g147_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-2&pf_rd_r=1KPZTB5NEGPDVCPEA976&pf_rd_t=101&pf_rd_p=467128533&pf_rd_i=468294
Problem 2
