Alright, I have a ton of experience with computers, but have never built a server. I've been asked to build a server for a business, but have absolutely no idea what to go with. The server needs to be on at all times, it needs to be able to run a simple employee time clock software(it will be the monitoring end of the software), and it will have the business quickbooks database on it(will be accessed from another PC in the office). I would like for it to work like a NAS where it would backup 3-4 PCs, one of those being a laptop. Also, these 3-4 PCs are all connected using wireless to the network.
I basically need suggestions on what hardware I should go with, if I should go with a RAID controller(separate card or on-board), what OS I should go with(whether you guys think basic windows would suffice or if I should go with windows server or windows home server and so on), and if it is possible to do all of this including making it somewhat like a NAS. If so, what software should I use for the NAS feature. I'm running pretty much blind here on the server end because I can build and I'm sure i'll have no problem managing it, but getting there is my problem. Thanks in advance for any help
