I am building my first system and am a bit inexperienced with the process specifically with setting up RAID volumes.
Here is what I have:
- i7 2600k
- Crucial M4 128 GB SSD with Windows 7 Pro
- ASRock Extreme 4 Z68 MoBo
- 2 SATA 3 WD Black 1 TB drives I just purchased (not yet installed)
The system is up and running currently with the single SSD
What I would like to do:
- Set up both WD drives in RAID 0 using SSD as the boot drive
- Use All 3 drives on SATA 3 connectors if possible (the board has 4 SATA 3 connectors but 2 are Marvell)
- If the above is not possible, what is best coinfiguration (SSD on SATA II, HDDs on SATA 3 or vice versa)
I have other questions as well but would like to know if this is possible before I get too carried away. I tried searching for other posts but couldn't find anything similar to my situation. Thanks for any info and help in advance.
- i7 2600k
