Need Help with Shadowplay Default Save Location
Shadow Legacy
17
First and foremost, I hope that this in the right section. If not please advise, and I'll move to the correct forum/topic. Ok, So I started up Shadowplay after a new build, since I heard it was a non-resource hog, way of recording gameplay. Sadly I've immediately run into a problem. I cannot seem to change the Save location for recordings. The default for recordings is to my C: drive which is an SSD and "Temporary Files location" is also on the C drive. I don't(in fact I'm sure many don't) want to have that many writes to the ssd. I've tried clicking on the button, that's usually where I'd be able to change save location but it give me an infinite mouse-pointer-blue-loading-circle(for lack of better description).
http://minus.com/i/brmWqKGKpRdPW
So I've looked up many topics on the matter and I found many similar posts like this one:
http://forums.evga.com/ShadowPlay-continuously-writes-to-SSD-m2047662.aspx
Many other users on different sites have recommended to move the temp folder in "advanced options" in Change environment variables and Change both the location of the TMP and TEMP folders. I have done this, and have restarted Windows, but sadly the they still save to the same location on the C Drive even after changing. I even wrote the location identical but for a different, much larger HDD ( E:\Users\[User Name]\AppData\Local\Temp), no dice.
If it matters I'm the only user on the machine, and have administrative privileges/rights. I've also updated all drivers and Geforce Experience. Would I need to uninstall Geforce and try to change environment variable again, than re-install GFE? I'm hitting a wall on this one( unless I just answered my own question above). I'll post results on that solution.
My System Specs:
MSI z87-g45
Intel I7 4770k
Nvidia GTX 980
16gb DDR 3
Corsair Neutron 240gb SSD
Western Digital 1.5TB x2 HDD
Any help would be greatly appreciated. I did one Shadowplay recording in 2560 x 1440 and a 5 minute clip took only 1.5 gb, at 60FPS. May seem a lot, but I have Fraps and a clip at the same resolution at only 30 frames, took up 14gbs for 4 minutes 30 seconds... See why I want Shadowplay to work as intended? I tried DXtory, but the minute I hit record it makes any game crash, using any codec. Still frustrated on that one, Might make another topic later on that issue.
I had no problem changing the default folders.
I assume you're at "GeForce Experience-> Preferences->Shadowplay" with the two links (one temporary) at the bottom.
Well, these work for me so if you have issues maybe try reinstalling your NVidia drivers and have it do a "clean" install (not "express").
*To be clear, I just click the "..." symbol for the links and Windows Explorer pops up to let me choose where I want the folder changed to.
(You may wish to investigate assigning a RAM CACHE since you have 16GB available. You could use that for the temporary location which I assume is the continuous write which records whatever you're doing if you have that option enabled (default 5 minutes)).
If you're certain you don't care about saving your gameplay I'd recommend turning off recording completely anyway. The hit on frame rates is generally no more than 5%.
Yes I am. It just gives me a mouse pointer loading circle whenever I click any of them to change. I'm gonna do a clean installation of Nvidia drivers and GFE see if that does anything.
I actually plan to edit and render gameplays with commentary, so I would need to save the files. i will post back my results
I reinstalled Geforce experience and did a clean installation of Nvidia graphics driver and it still gives me a blue spinny circle of death when I try to change the location of both Temporary and Saved videos location.
I always seem to have unique problems when it comes to PC. Just like DXtory giving me exception errors, that deal with .Net framework issues, even though they have been updated/re-installed/etc. but that's an issue for a different day.
I guess I may be stuck with Fraps and it's massive files if I can't get any of these to work.
