Need help with silly question
G
Guest
Guest
Archived from groups: alt.games.everquest (More info?)
My EQII main menu button (lower left of screen) has disappeared and I cannot
get it back. I'm sure it's something simple, but for the life of me I
cannot find it. Hard to play without access to menus.
thx.
"jakesnake66" <jake@lycos.com> wrote in
news:5_ZFd.1954$re1.978@fe2.columbus.rr.com:
> cannot get it back. I'm sure it's something simple, but for the life
> of me I cannot find it. Hard to play without access to menus.
I didn't know you could make that button go away, but I have a couple of
suggestions.
Did you change your display resolution in the game so that maybe it was
pushed out of the visible area? I don't know if it actually behaves that
way or not.
Did you play with the letterbox setting to make the black areas at the top
and bottom of the display too small, allowing the game view area to cover
up the button? Again, I don't know if that setting would cause that or not.
Rumble
"Write something worth reading, or do something worth writing."
-- Benjamin Franklin
"Rumbledor" <Rumbledor@hotspamsuxmail.com> wrote in message
news:Xns95DF72BC18B33Rumbledorhotmailcom@204.127.204.17...
> suggestions.
> way or not.
not.
Thank you for your input, but, no, as far as I can tell I didn't do any of
those things prior to the problem. At least the button isn't pushed off the
screen because of resolution (I have made display setting changes from time
to time). Everything else looks normal. A friend of mine says he vaguely
remembers hearing of a rare glitch that causes this, but he didn't remember
the details, and he didn't have a fix. Very strange.
Alt-` gets the button back.
that's the alt key and the aposterphe key to the left of the 1.
