so i might get another 760 cheap off ebay, and plan to sli it, it wont be the same brand or clock speed but will have the same chipset. i might need a new power supply, what do you recommend. also will i have any problems with the Mobo i have? also by have 2 760 what gpu power am i close to like 780? or higher?
Mobo- GIGABYTE 970A-UD3P AMD970
8 Gb ram
gtx 760 zotac amp (current GPU)
windows 8.1 pro
CPU - FX-6300
PSU- 550W xfx-tsa55
8 Gb ram
windows 8.1 pro
CPU - FX-6300
PSU- 550W xfx-tsa55
