And7rey Distinguished Nov 3, 2012 277 0 18,790 Jan 12, 2014 #1 I stick my earphones in the audio port on the front panel, but the speakers keep on working . What could be the problem? What should I do?
Solution alexoiu Jan 12, 2014 I see. Check here: http://www.tomshardware.co.uk/answers/id-1813300/separate-speakers-headphones.html
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Jan 12, 2014 #2 Is front panel jack detection enabled or disabled? Upvote 0 Downvote
And7rey Distinguished Nov 3, 2012 277 0 18,790 Jan 12, 2014 #3 alexoiu : Is front panel jack detection enabled or disabled? Its enabled and the earphone works fine , unfortunately the speaker works when earphones are plugged in Upvote 0 Downvote
alexoiu Titan Nov 1, 2012 39,817 250 126,990 Jan 12, 2014 Solution #4 I see. Check here: http://www.tomshardware.co.uk/answers/id-1813300/separate-speakers-headphones.html Upvote 0 Downvote Solution
