G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I am about at the end of my rope with my daughters computer. She has AdWare
or whatever. I have run Spybot S&D v1.2, Spyware Doctor v3.2.1, Microsofts
Anti Spyware v Beta 1 and Ad-Aware SE. I have run them all numerous times
and the last time I ran As-Aware, it didn't find anything I've taken our
over 600 bugs. After all of that, when I connect to my ISP either FireFox or
IE, the screen goes crazy with adware screens and I get continuous IE errors.
I have all the MS updates.
Any suggestions?
Thanks Larry
G
Guest
Guest
Hello Larry,
Try this,
Internet Explorer/ Tools/ internet options/ where it says deleate Internet
Files, click deleate files, in same window click deleate history.
Return to desktop, start PC in safemode, run a full virus check then run
your spyware programes while in safemode.
When all is done exit safemode, restart PC, return to Desk top
Hope that helps.
Sandal
> Any suggestions?
> Thanks Larry
G
Guest
Guest
Canon
You do not have the latest versions of any anti-spyware program.. download
them now, install, update, and run them.. also add Spyware Blaster to your
list, and use it in place of Spyware Doctor.. it is important to keep up to
date, not just with updates, but versions too..
Also, ensure that you are running a decent firewall.. the SP2 firewall is
better than none at all..
You might also want to take a look here.. bookmark the page too..
http://www.pchell.com
Mike Hall
MVP - Windows Shell/User
"canon1a" <canon1a@discussions.microsoft.com> wrote in message
news:A8CF1031-03AF-425D-A499-61F3DA551F0C@microsoft.com...
>AdWare
> Microsofts
> or
> errors.
> Any suggestions?
> Thanks Larry
G
Guest
Guest
Hello, Very good advice and links, follow the recommendations given. Two
other items that may help: 1. check if the pop up stopper in IE6 is active
(tools, pop-up blocker). 2. visit this site and consider installing a "hosts
file" http://www.mvps.org/winhelp2002/hosts.htm.
take care.
beamish.
> Any suggestions?
> Thanks Larry
G
Guest
Guest
Try running a scan with Ad-Aware while in Safe Mode.
Donny Broome
donny AT broomeman DOT com
Kill Spyware! Visit:
http://www.broomeman.com/spyware/
>AdWare
> Microsofts
> or
> errors.
> Any suggestions?
> Thanks Larry
G
Guest
Guest
The current version of Spybot is 1.4. Download, install, update and run all
of the following.
Ad-Aware
http://www.pcbutts1.com/downloads/aawsepersonal.exe
Spybot search and destroy
http://www.pcbutts1.com/downloads/spybotsd14.exe
Ewido Security Suite Trial version
http://www.pcbutts1.com/downloads/ewidosetup.exe
Microsoft Windows AntiSpyware (Beta1)
http://www.microsoft.com/downloads/details.aspx?FamilyId=321CD7A2-6A57-4C57-A8BD-DBF62EDA9671&displaylang=en
If none of the above fixes the issue then download Hijack this, run it, save
a copy of the log file and cut and paste it back here to this group so that
I can analyze it. Ignore anyone especially the troll Leythos, who will tag
along a nonsense post to this message, who tells you to post it elsewhere. I
need to see it not them.
HijackThis
http://www.pcbutts1.com/downloads/HijackThis.zip
The authors of the above programs, with the exception of Microsoft has given
the owner of pcbutts1.com express written permission to redistribute their
software.
The best live web video on the internet http://www.seedsv.com/webdemo.htm
NEW Embedded system W/Linux. We now sell DVR cards.
See it all at http://www.seedsv.com/products.htm
Sharpvision simply the best http://www.seedsv.com
>AdWare
> Microsofts
> or
> errors.
> Any suggestions?
> Thanks Larry
G
Guest
Guest
All your anti-spyware software "MUST" be updated to the latest versions.
Other things to try:
CWShredder
Hijackthis (with help from various HJT web forums)
Trend Micro's Housecall web scan.
>AdWare
> Microsofts
> or
> errors.
> Any suggestions?
> Thanks Larry
G
Guest
Guest
Make sure Spybot S&D is upto date.
Then run it in advanced mode, click the tools button (lower left area)
in the main window, make sure the BHO's & ActiveX options are checked,
then select BHO's in the left pain to see what loads with IE.
Review the names, and location of each BHO, and any you wish to remove, can
be by selecting it and clicking Remove.
>AdWare
> Microsofts
> or
> errors.
> Any suggestions?
> Thanks Larry
