I have a question regarding an SSD I am about to install. I recently purchased the Kingston HyperX 3k 120GB SSD because a driver I installed on my current HDD is causing a black screen on start up, and I'm unable to access anything without booting with another HDD. I spent a fully day trying everything I could to fix the issue before finally giving up and just buying an SSD, which I've needed for a while anyway.
So in short, I'm going to use the SSD to boot with, and my HDD which can no longer properly boot as storage. (I've tested this already, I can access my files just fine as long as I boot with a different drive.), but here's the problem:
I have a Radeon graphics card, and I've heard that for my SSD to work, I need to enable AHCI prior to installing Windows 7. I am able to do this, but once I enable AHCI, and try to boot with my old hard drive, I get a BSOD. So here's my question:
If I enable AHCI and install windows 7 on the SSD, will I still be able to access my HDDs files? Will the AHCI mode affect my ability to access them, or is AHCI only an issue if I attempt to boot with the HDD?
Any insight would be greatly appreciated!
