need help with telnet
solidtom
7
Greetings, I purchases a replacement tl-wr703n for my Avalon bitcoin miner, and I am having problems configuring it. these are the instructions i received for troubleshooting:
Hi,This module's default IP address is [removed],To access the configuration console you need to set your computer LAN port IP address as [removed] (eg. [removed] ). If you confirm your LAN configuration is OK, please follow the guide to reset the module.
1. Module do not connect the USB cable (Cut off the power),connect the module with network cable to your computer, direct, don't via a router or hub.
2. pls connect the power while you press the Reset (notice: press the Reset once each of sec not keeping press)
2. loose the Reset key when the blue light begin to flash(the blue light flash quickly when you loose)
3. now set the compute IP for [removed]
4. running telnet [removed] on the computer ,running below order when you log in
mount_root?enter?
rm -rf /overlay/*?enter?
reboot?enter?
after this operating ,the 703n will go back to the original state
now you can visit [removed] (Remember to change your computer's LAN IP address to the same segment, for example [removed] )
Where I am stumped is running telnet on [removed] I have telnet server and client installed i figured that part out.
but when I do i get the error:
http://www.imagebam.com/image/e294ee315205859
or
e294ee315205859
how do i fix this? it has me stumped.
Personal IP addresses removed. Please do not post this information as this is a public forum and it can leave your network open to attacks from hackers and phishing scams. - G
