• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Need help with Temperature related questions
Aditya657
64
9
Hello!
I have a HP Envy 14 J-007tx and it's specs are an Intel i5200u @ 2.20 GHz, 12 Gigs of Ram and a Nvidia GeForce GTX 950M. I've been playing games such as world of tanks, Armored warfare etc etc on medium or high settings and the thing is that my laptop seems to get hot(it feels kinda hot from the top near the power button but below the body it's reaallly hot)I've not checked my temps through core temp or something if it's advised i will do so and After let's say the laptop remains hot for like 30 mins ( maybe more or less I'm not sure) My FPS drops it does and my game starts lagging... I've tried switching my quality to low and It still happens... Is this really normal or should I do something about this cause the laptop was bought in November 2015. I will be grateful for your help. Thanks in advance
-Aditya
Aditya657
64
9
I checked that thing which you said but Since I'm in India it will cost me quite a bit to get the one you are suggesting here and that one is not available in Websites of here. I found this one(putting it in the end). Do you think it'll do the same job and keep my laptop cool while gaming and such and it says compatible with all 17 and smaller laptops so mine is 15.6 inches.. Will it be fine? Thanks for the reply.
http://www.flipkart.com/cooler-master-notepal-l1-cooling-pad/p/itmdyh7fzpggufdc?pid=ACCDYH7DHYZYDQMH&ref=L%3A-6185568681165306432&srno=p_1&query=Laptop+cooling+pad&otracker=from-search
Barney6262
973
174
External laptop coolers will not help your laptop throttling. It just stops the bottom of the laptop being too hot for it to be placed on your legs:
https://www.youtube.com/watch?v=T3zcat1-8D0
Your CPU is throttling because the internal cooling system is not able to cope with a CPU at 100% use. There is no easy fix for this, assuming the thermal paste isn't the issue.
Solutions:
Try asking for the Thermal paste to be re-applied.
Try replacing the laptop
Get a more gaming orientated laptop.
If non of these are an option I'm afraid you are out of luck.
Similar threads
