Question Need help with testing for leaks on liquid cooling system
kwikvinny
228
8
4,595
I currently have a liquid cooling loop with a Distro plate/Reservoir which is mounted to the front of the case replacing the glass front panel. Also there is one 360mm radiator and one 120mm radiator. Last thing is the actual motherboard which has built in liquid cooling which cools the cpu and vrms. Its a Asrock z490 aqua motherboard.
So my question is how much pressure is actually produced with one d5 pump in this system? I can hold over .25 lbs of pressure literally overnight. But I can't hold .5lbs of pressure at all. So should I wait on some new tubing or is a .25 lb enough to not have a leak?
