Question Need help with this, 4K gaming and entertainment,
blade_d
36
Hey all, I mostly wanna play games at 4k and some csgo at 1080p 144hz and netflix. So I'm a little confused betwen the choices below. Help me chose the right spec:
Shall i go with r5 3600 with 2080ti? Or R5 3600 with 2080 super Or r7 3700x with 2080 super or 2080 ti
Also 3200mhz memory 16 gigs Some x570 mobo that will research separately.
Note: i don't plan on upgrading the gpu and cpu at least for the next 5 years or so. So please suggest accordingly. Also keep the bottleneck in mind. I don't want that 😂 Zero productivity at all.
Any help would be appreciated. Thanks.
I think I myself would look into pairing a 3600x with the 2080ti. You most definitely want the ti card for the 4k gaming.
others may suggest another cpu though if you don't want to replace it for the next 5 yrs..
Reactions: blade_d
