need help with this adapter dvi /vga?
Mar 7, 2018
is this adapter a dvi-i to vga the which i need or is it just a scam....... i can't identified in the picture
ps;sorry for my english i am from france (merci a vous)
Barty1884
That adapter will take a DVI-I connection (which carried both digital and analog signals) to VGA (analog).
Whether your GPU has the analog signal or is digital only, will depend on the specific GPU you have.
Anything GTX 10 series or RX4/RX5 is DVI-D Dual (digital) only. Anything prior *should* have DVI-I.
Mar 7, 2018
i a have gtx 950 it has dvi-i and dvi-d ..but i don't know if this adapte is dvi i because only dvi i can convert to vga! i think
