I need some advice for a new build I'm doing. I'd like to satisfy my use-cases for at least a few years. Those are...
Because a couple of the machine learning libraries I use don't support GPUs, I want to do resource intensive virtualization, and adding more CPU power will obviously keep my build relevant to me longer, I've been thinking about using a dual socket board. In particular the ASUS Z10PE-D8 WS (http://www.newegg.com/Product/Product.aspx?Item=9SIA2F84D69056&cm_re=Z10PE-D8_WS-_-13-132-268-_-Product) in which I would place two i7-6850K (http://www.newegg.com/Product/Product.aspx?Item=N82E16819117647&cm_re=i7-6850K-_-19-117-647-_-Product). Plenty of speed and PCIe lanes (40 per chip). Asus lists Xeons as being compatible with that board but I believe Broadwell-E will work in it. Or should I just use some comparable Xeon model? Of course then overclocking is largely missed out on. Plenty of RAM slots for virtualization and I was also thinking about trying RAM disk for various applications including games. The 4-way SLI of the board is important to me though I'll be starting out with two GTX 1080s.
As for the dual-cpu issue, I read a post from April saying the BIOS for the board would support Broadwell-E shortly. I've seen no posts since. Maybe it's in the changelog if I can find it. This thread is mostly to weigh in on the board and CPU(s) and what other options (If any) I might entertain. I know some might say that dual CPU sockets aren't necessary but I believe that the use-case of my programming libs and running several OS simultaneously on a hypervisor warrants it.
Some case, cooling, and PSU recommendations would be appreciated as well.
thanks!
Running deep learning libraries against CPUs & GPUs (Very important)
OS virtualization with VGA passthrough (Would be nice)
Audio & video production.
VR gaming.
thanks!
