Ok so I've gotten some help already and I have somewhat of a plan. My official budget is: $asmuchasIcanspendwithoutmywifeknowing.00
That said, I don't know the exact figure, but when I'm done with my entire current build I want a high end oc-able SLI machine at 1440p.
What I really feel I need next is my SSD but theres quite a few complications. Cloning to avoid buying a new mobo/case/OS now would mean needing another drive to back up on. Then, navigating the cloning process which differing articles don't seem to agree on if it's even a good or proper undertaking. Some say User Files NEED to be on the SSD, some say no. Seems if you have Windows 8.1 then you do need them on the SSD. How do I properly calculate how big the SSD would need to be for cloning?
Now, this is what I'd like to do for my next move.
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard ($199.99 @ NCIX US)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($99.79 @ OutletPC)
Case: Corsair 200R ATX Mid Tower Case ($56.98 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($87.79 @ OutletPC)
Total: $444.55
Generated by PCPartPicker 2015-04-20 19:12 EDT-0400
I have many questions though...
1. That's a nice board with the ocing capabilities that I will need once I move from my i5 4440 to the i5 4690k that will come later. Is it overkill? Is there something "better" I should consider? Something less expensive with similar features?
2. Is that SSD gonna be big enough? I have a 1TB WD Blue 7200 rpm right now with 600GB+ data. I want at least the OS on it. Maybe games as well. Again, the User file issue seems to rear its head.
3. Is this case any good? Will my MSI GTX 970 Gaming 4GB fit in it? It looks it but.. idk.. Does it have good airflow that I will need for my later CPU upgrade? Will a quality cooler fit in it? Does anyone have a better suggestion?
4. I am aware that I could get the free version of Windows 10 but that seems like a whole new scarey ball of wax added on top of big upgrades that I will be doing for the first time. Any reassurance out there that it will be easy or warnings that perhaps I may be biting off more than I can chew?
Thanks for helping in advance.
Total: $444.55
