Hi all,
Windows 10 user swapping to a new mobo, cpu, and ram, AND adding an m.2 to boot from. Trying to understand what my order of operations should be. Goal is to swap out the listed hardware, and reinstall my windows to the m.2 drive (or clone it, windows currently boots from a SATA SSD I have). Seems like there are a few different methods I might want to use, not sure what the best way to go is.
Ive read windows wont boot with a new MOBO and that I'll need a fresh installation of windows even if i'm not changing drives. Can someone confirm I need to make an installation USB drive if I am changing MOBO?
If this is true and I need to do a fresh install of windows, I'm guessing its better to assemble the components with ONLY the new m.2 drive installed, enter bios and install to the m.2 with the usb stick, and activate the product with my microsoft account. OR would it be better for some reason to do the fresh install of windows to the current SATA SSD I have it on now, get the system stable on my existing SSD, THEN install the m.2 and clone the drive? I'd prefer to have the smoothest transition possible, dont want to lose data and settings etc.
Another option possibly would be to clone the SATA SSD drive to the m.2 in my current build before making any other hardware changes. Would that be better for any reason? I think i'd still have to reinstall windows to it once I swap the mobo but wonder if theres some advantage to getting windows on the drive before doing the fresh install that the mobo will require.
Any advice is welcome, I built my current pc back in 2016 and have only updated GPU, so I'm just not familiar with a process like this. If more info is needed please let me know and ill provide it, Thanks so much
