Hello all,
I have a gateway fx6860 ur20p desktop pc with the i7-2600 3.4 cpu and 8 gb ram.
the video card is a 1gb 6750 hd radeon. This card is only meeting the minimum requirements for most games id like to play. so im looking at upgrades and like the geforce gtx 660 2gb. Would you all recommend this gpu or is their another i should be looking at?. Also, I am not sure if it would be compatible with the motherboard inside? my power supply is 500 watt, would this be sufficient for this video card?
Thanks in advance
-John
Thanks in advance
-John
