I was given a computer from a friend which is pretty old.
The motherboard is shot and uses the 939 socket. Since getting an old motherboard cost more then upgrading it, I was hoping to just upgrade it.
I've priced out some things and I'm hoping to just buy a motherboard and cpu and be done with it.
the problem is I'm not sure what my power supply can support and I'm not sure if I will want to have to spend more on a power supply.
Right now I was looking at the
Phenom 9600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103244
and
GIGABYTE GA-MA78GM-US2H
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128379
Combo, but I'm not sure if my power supply can support it.
I'll be using the onboard video card and will not be adding another card.
The current power supply is a 350W Power Man.
Its has a 12v Rail of 18A
I have a SATA and PATA hard drives
the SATA is a 500GB and the PATA is a 250GB, I'll use whichever one needs less power.
Will that be enough to power the CPU, Motherboard, Hard Drive optical drive, and 1 80mm + 1 120mm fans?
Phenom 9600
and
