Hi guys,
I have two questions/problems, let's get right into it.
So I've just built a new PC with a case that has an USB 3.0 port in the front panel, however my motherboard doesn't support the cable that comes from that USB 3.0 port. So I was wondering if there's a cable that converts that USB 3.0 motherboard cable to a SATA cable.
The second problem is that the USB 3.0 ports on the back of my motherboard aren't working, I've enabled them in the BIOS. How do I get them to work? I guess it has something to do with the drivers but I can't seem to find them.
Specs:
MB: ASRock 990FX Extreme3
CPU: AMD FX6300
GPU: MSI R9 280X
Case: Cooler Master N300
OS: Windows 7 Ultimate
Best regards,
Thomas
Specs:
CPU: AMD FX6300
GPU: MSI R9 280X
Best regards,
Thomas
