Need help with using Steam on multiple drives
ShadowsVoid
423
Hi, I've just reinstalled Steam onto my SSD and I want my games to be on my HDD because my SSD simply isn't as big enough.
First, I go to Settings, Downloads, Steam Library Folder and then add folder. This folder is on my HDD. But then, an error appears saying "New Steam folder isn't writable". I don't know what to do, please halp!!
USAFRet
That would appear to be a permission issue. What folder are you designating in the Steam client?
Try this:
Create a whole new folder on the HDD - "Steam Games"
Point the "Steam Library Folder - Add Library Folder" at that.
See what happens.
That scenario works perfectly for me. Even across multiple drives.
USAFRet
Ahhhh....OK.
It would seem that the "D:\Program File (x86)\Steam" is the folder from an older Windows install, still resident on the HDD.
That folder would be semi-locked to the old NTFS userID. And as such, makes it harder to access. Even if the username is the same, the NTFS permissions are not the same.
Create a brand new folder on that drive, point Steam at that new folder, and see what happens.
After that works, you can look into taking ownership of that "Program Files" folder.
USAFRet
Create new root level folder on the drive in question.
Call it "Steam Games" or something. But a folder NOT under the "Program Files".
In the Steam Client:
Settings - Steam Library Folders - Add Library Folder
Browse to the drive and folder you just made
Click Select
That's it.
ShadowsVoid
423
I just did that but it's still coming up with the error "Failed to add Steam Folder" :/ Thanks for helping me by the way :)
USAFRet
hmm....
Completely outside of the Steam client, can you add just a regular file to that newly created folder? Copy/paste?
USAFRet
OK:
In the same process, "Add Library Folder - New Folder"
Be sure you navigate to the top level of the desired drive
Give it a name
Click OK
It's hard to diagnose when I can't repeat the fail mode. And I seem to have zero issue designating, or creating, a new folder for Steam to use.
I just added 4 in various modes.
ShadowsVoid
423
Nope, still "Failed to add new Steam folder". It isn't in Program Files, or anything else.
USAFRet
Again....hmmmm...
ShadowsVoid
423
I think I'm just going to resort to using Steam Mover. Same concept but an added program. Thanks for helping :)
USAFRet
Yeah, give it a try and see what happens.
ShadowsVoid
423
Seems to be working so far so good. Shame I can't use my 3rd drive as Steam mover can only support one at a time. The error still occurred on that drive too. Hopefully Steam will release a fix! (doubt it).
USAFRet
Possibly a client version issue. What version is your client?
Mine is Oct 8 @ 18:04:08
API v012
areyourosh
4
Hey dude i dont know if youre still interested in this thread but i was having the exact same problem as you and i think i may have found a fix for it. If your still interested, let me know.
Cheers!
ShadowsVoid
423
I already fixed it, fixed randomly. But if anyone finds this thread, then your solution could help out
areyourosh
4
Same here, was a completely random fix, but i dont care because its finally working, haha!!
Glad to hear your issue was resolved as well, if anybody else is having trouble with this issue, reply to this thread and i should be able to walk you through it!
ShunTheShine
6
I need help. Thank you!
areyourosh
4
What have you tried so far to get it to work? To eliminate the possibility of me giving you advice you have already experimented with.
konawolv
178
If this wasn't suggested earlier, look up MKlink and how to use.
Here is a good tutorial:
https://www.youtube.com/watch?v=TIVNLPz3wfI
Using MK link allows you to also move games from drive to drive as you see fit. Its really cool. Been using it for 2 years now.
In short, what it does it tricks steam into thinking its installing and accessing games on one drive, when in fact it is accessing them somewhere else via a virtual link.
