need help with VRM + VRAM safe temps for gtx 1080 ti
Pachuca
11
Hi, I have gtx 1080 ti. I use a Kraken G10 with a corsair H50 AIO liquid cooler on it. To use this I had to remove the stock cooler and all of it's components. I'm worried that the vrm and vram might be getting too hot during use because these are usually under a heatsink with thermal pads, but right now the only way they are cooled is from case air flow. My case airflow isn't great so I'm worried that these will overheat while gaming. I haven't seen any issues, but I wanted to know what exactly are the safe operation temperatures for the vrm and vram on a gtx 1080 ti? Is there anything I should to in order to provide cooling for them or is it unnecessary?
actually found my answer online already. Temps for vrm and vram decrease and the card runs better when the components are without any heatsink on them. hope this help if anyone has the same question later.
