Question Need help with "WHEA_UNCORRECTABLE_ERROR" BSOD
Oct 18, 2021
Not sure if this is the right place to post this so please someone correct me if I'm wrong.
Anyway, for about a week or so I've been experiencing bluescreens (WHEA_UNCORRECTABLE_ERROR)
At first I suspected that it might've been either my PSU or thermals, so I bought a new power supply and AIO cooler, but obviously, that didn't help.
I should also note that I bought a new motherboard as well, I even reset the bios & updated to the latest bios on it so I know it's nothing to do with the motherboard.
I ran Furmark, Prime95, memtest86, and chkdsk all without any errors, but I suspected that it was a memory issue wince it usually seemed to crash when in a loading screen, or soon after.
Old PC Specs:
Ryzen 5 5600x w/ Wraith Stealth Cooler
Gigabyte Eagle RTX 3070
ASUS ROG B550-f
EVGA 600w Bronze PSU
GSkill Ripjaws 16gb 3200MHz RAM
Parts I replaced:
MSI MPG B550i
CoolerMaster 750w Gold PSU
CoolerMaster ML240l V2
I read about Minidump files and decided to enable them. Now, I know absolutely nothing about minidumps but mine seem to be saying that it's a memory failure.
I'll try to post all the relevant information below:
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the WHEA_ERROR_RECORD structure to get more details.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffa788910db028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000bc800800, High order 32-bits of the MCi_STATUS value.
Arg4: 00000000060c0859, Low order 32-bits of the MCi_STATUS value.
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 2233
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 2274
Key : Analysis.Init.CPU.mSec
Value: 280
Key : Analysis.Init.Elapsed.mSec
Value: 33654
Key : Analysis.Memory.CommitPeak.Mb
Value: 91
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
BUGCHECK_CODE: 124
BUGCHECK_P1: 0
BUGCHECK_P2: ffffa788910db028
BUGCHECK_P3: bc800800
BUGCHECK_P4: 60c0859
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: chrome.exe
IRP_ADDRESS: ffffffffffffff89
STACK_TEXT:
ffffba81bc76a948 fffff8001730200b : 0000000000000124 0000000000000000 ffffa788910db028 00000000bc800800 : nt!KeBugCheckEx
ffffba81bc76a950 fffff800165610c0 : 0000000000000000 ffffba81bc76aa29 ffffa788910db028 ffffa788910db028 : nt!HalBugCheckSystem+0xeb
ffffba81bc76a990 fffff8001743fc33 : 0000000000000000 ffffba81bc76aa29 ffffa788910db028 ffffa7888c1fc300 : PSHED!PshedBugCheckSystem+0x10
ffffba81bc76a9c0 fffff800173039fd : ffffa78890b5d0c0 ffffa78890b5d0c0 ffffa7888c1fc350 178bfbff7ed8320b : nt!WheaReportHwError+0x393
ffffba81bc76aa90 fffff80017303e48 : 0000000000000009 ffffa78800000003 fffffd8abb5b9000 0000000000000009 : nt!HalpMcaReportError+0xb1
ffffba81bc76abf0 fffff80017303cdc : ffffa7888ace96c0 0072006f00000000 ffffba81bc76ae00 0072007000000000 : nt!HalpMceHandlerCore+0x138
ffffba81bc76ac50 fffff8001730317b : ffffa7888ace96c0 ffffba81bc76aef0 0000000000000000 002e007400730065 : nt!HalpMceHandler+0xe0
ffffba81bc76ac90 fffff80017305afb : ffffa7888ace96c0 0061006600200072 00640065006c0069 0020006f00740020 : nt!HalpHandleMachineCheck+0x97
ffffba81bc76acc0 fffff80017365959 : 0042002000650068 006f004c00740069 00720065006b0063 006c006f00760020 : nt!HalHandleMcheck+0x3b
ffffba81bc76acf0 fffff800172226fe : 006b002000720065 0066002000790065 0020006d006f0072 0020006500680074 : nt!KiHandleMcheck+0x9
ffffba81bc76ad20 fffff80017222328 : 0000000000000010 0000000000000000 fffff80017af8980 0000000000000000 : nt!KxMcheckAbort+0x7e
ffffba81bc76ae60 fffff800170de478 : 0000000000000000 ffffa78894965540 0000000000000070 0000000000000000 : nt!KiMcheckAbort+0x2a8
fffffd8abb5bf610 fffff8001705b397 : ffffba81bcf80180 ffffba81bcead1b8 fffffd8abb5bf7b0 fffff8001705a81f : nt!KiDeferredReadySingleThread+0x6d8
fffffd8abb5bf700 fffff80017030885 : 0000000000000000 ffffa78800000000 ffffa78800000001 ffffa78800000000 : nt!KiExitDispatcher+0x167
fffffd8abb5bf7b0 fffff80017497d30 : 0000000000000001 0000000000000001 ffffa7889fe79d00 ffffa788a40612c0 : nt!IopCompleteRequest+0xad5
fffffd8abb5bf880 fffff800174b4f3d : ffffe40900000000 fffffd8abb5bfb20 000000c4c0bfd3f0 ffffa7889fe79d30 : nt!IopSynchronousServiceTail+0x2e0
fffffd8abb5bf930 fffff80017225078 : 0000000000000000 0000000000000000 0000000000000000 0000625a000e8798 : nt!NtWriteFile+0x63d
fffffd8abb5bfa30 00007ff9e2b833d4 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : nt!KiSystemServiceCopyEnd+0x28
000000c4c0bfd358 0000000000000000 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : 0x00007ff9`e2b833d4
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD.sys
STACK_COMMAND: .thread ; .cxr ; kb
FAILURE_BUCKET_ID: 0x124_0_AuthenticAMD_MEMORY__UNKNOWN_FATAL_IMAGE_AuthenticAMD.sys
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {b0905187-9dbc-d607-4dc5-8630b9eddb7f}
Followup: MachineOwner
Common Platform Error Record @ ffffa788910db028
Record Id : 01d7c36eae4e6b78
Severity : Fatal (1)
Length : 1019
Creator : Microsoft
Notify Type : Machine Check Exception
Timestamp : 10/17/2021 16:47:12 (UTC)
Flags : 0x00000000
Section 0 : Memory
Descriptor @ ffffa788910db0a8
Section @ ffffa788910db1c8
Offset : 416
Length : 80
Flags : 0x00000001 Primary
Severity : Fatal
Physical Addr.: 0x00000001004dee00
Section 1 : Processor Generic
Descriptor @ ffffa788910db0f0
Section @ ffffa788910db218
Offset : 496
Length : 192
Flags : 0x00000000
Severity : Fatal
Section 2 : x86/x64 MCA
Descriptor @ ffffa788910db138
Section @ ffffa788910db2d8
Offset : 688
Length : 292
Flags : 0x00000000
Severity : Fatal
I really can't tell if it's a CPU problem or a memory problem, it seems like a memory problem to be but I'd like an experienced opinion before I RMA anything.
Thanks,
Jared.
