Hi,
I am in the UK using a Virgin superhub 2. My WIFI signal downstairs is fine, however it's pretty slow/unreliable upstairs.
I have bought a DLink Powerline starter kit, so that I could give my son a "wired" connection upstairs, however this doesnt solve the problem of normal WIFI upstairs.
I recently found an older DLink wireless modem (Think its the DLink 615 one), and wondered where the best place to put the wired ethernet cable is. Is it best to use on of the LAN input, or should I put it into the Broadband input. I have no idea, but having quickly tested it in one of the LAN inputs the conncetion seemed better than before.
Thanks for your help and going through all the above TL: DR.
