Need help with wiring front panel connectors
Josh42398
Hello, I can not figure out where to plug the front audio and microphone jacks from my xion slim case to my msi a55m p33 motherboard. I tried the manual, but it is useless. Has anyone else had the same experience/problem and been able to resolve it?
These are the connectors i cannot figure out where they go in JAUD1.
MIC IN(R) - GND
LINE OUT FL - LINE OUT RL
LINE OUT FR - LINE OUT RR
MIC POWER(L)
the audio conector for the case should have been keyed. if your looking at the connector. the missing pin in pin #8. the pins on that side are pins 2,4,6,empty,10.
pin one and three are for the microphone. pin 9 and 5 are head phone or output. pin 2 is a common ground. the reset are used for sense pins.
http://www.msi.com/product/mb/A55M-P33.html#/?div=Manual
Look at page 20
