my specs are
asus b550 prime plus
ryzen 5 5600x
Aorus Rtx 2080 super
32gb of corsair dominator ram at 3733 MT/s
CRAS c700 rgb NVME ssd 480 gb
Evga 850 gold nova gt power supply
corsair ICUE H100i Elite Capellix xt liquid cpu cooler 240mm
I was playing cyberpunk 2077 i have all my graphics settings almost at max except fog resolution its set to low i have ray tracing enabled using local shadows and raytraced reflections and running at 1080p resolution i get around 46fps to 58fps in some parts of the game then later on the fps drops to around 32fps and stutters when i look in the mirror is this a cpu problem or its the gpu or which graphic configuration you would recommend i try or should i use my 3060 12gb?
ryzen 5 5600x
