NEED HELP!
kamo287
7
i am looking to buy a laptop and a BIG deciding factor is...
WHAT IS BETTER
AMD Athlon™ 64 X2 QL-64 Dual-Core Processor
OR
AMD Turion™ X2 Dual-Core Mobile Processor RM-72
godless
624
i don't know what the real difference is. checking out amd official website, the specs are identical. same speed, cache, tdp, system bus, socket and 65nm process. i presuming that the difference is in architecture of the chip. since every other spec is the same, i'm assuming that the newer (RM) chip is going to be faster. either that or it's a case of rebranding.
godless
624
from what i can read up right now, the chip performance is identical. the newer turion has more power states and can save more power @ idle. the memory has been upgraded to ddr2-800 and improved HT link
godless
624
pretty much identical laptops to me. same chipsets (3200) hdmi, hd, 4gb vs 3gb ram is not an issue. they will perform the same except the acer will have better battery life. the best buy one has LED backlit screen.
i guess i'd go with the acer, bettery life seems to be only big difference.
kamo287
7
ok thanks. this info does help a lot.
i doubt it but the gateway might have DDR2 6400 ram- and the Acer 5400 ram- 800ghz and 664ghz right? would that make a big difference?
