• Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
[SOLVED] NEED HELP
Jul 26, 2019
16
I need help plsss I am tryna install windows 10 to my brand new PC but whenever It is at reading files 1%. and then it shows an error for installing, it says that the files needed are missing or corrupted and then when I try to re install it it adds more drives labled partition what can i do to fix it?
USAFRet
112,071
1,656
154,940
18,466
  1. Where did your Win 10 installation come from?
  2. During the next install attempt, you need to DELETE all existing partitions on the drive.
Jul 26, 2019
16
I bought a Win 10 Disc installation and used my external disc inserted into the PC.
