[SOLVED] need Help
b2k-justbetter
28
hello guys, I really need help about my laptop while gaming so here what's happeined
after i reset my laptop to factory windows because of a windows update that ruined my pc,now I have a huge drops fps(15-20) that happein while gaming for like 10 sec every 1 minutes then come back to 80-90fps
I checked my temps it always constants no overheating nothing for both cpu(75-85C) and gpu(64-80),the only solution that i found is that i reduce the maximum processor stat from 100% to 99%, it fixed the fps drops, but the game is not smooth as when put it on 100%,any solution please ?
my spec, asus laptop gl704gm i7 8750h and 1060 6gb
actually what I noticed is when I got the drops fps the temps of cpu get's low for like 70-75C, and in it normall play it goes for 88C
the first image is where I get drops,and the second and is in normal
It's dropping the CPU speed so it goes down to 70C. That's why you are getting issues because the CPU isn't working as fast as it should. 80C is too hot. You need to fix the cooling.
but bro when i put the process maximum stats to 99% the temps become less than 70, without any drops frames but no smooth at all and the games reduced to 60-70fps and less performance, I don't think is a problem of cooling 🙁
You can use this guide to undervolt your cpu , this is common "fault". Use first -100mv then try more if needed :
View: https://www.youtube.com/watch?v=R7OdTmylZNQ
bro every time i tried undervolt my cpu i always face the same problem which is blue screen no matter how much time I decrease those number my laptop always crach with blue screen, and I'm afraid to lost my laptop because of that 🙁
I still think cleaning and checking the fans would be much easier. But the OP seems to feel there is some other magic answer. Undervolting probably isn't it. Can't wait to see what is.
the fans are working properly it reach 7600 RPM for both cpu and gpu,I don't have experience about cleaning laptop, but it's still new only 6 month that I used, my room is cooled like 20 C, the weather also is cold so I don't know what to do,
I've searched alot I found some people have the same issues undervolting didn't solve that for them... still looking for answer, I really want to play using 100% in processor mamximum state because is so smooth but I really need a solution about those drops,and for intel turbo boos
