need help
lb19984
671
Soerry about that unreadable post but i was really pissed when i wrote that.
What i ment was when you run memtest86 there is a Bandwith in the upper right hand corne its right under the cpu speed so any way my memtest bandwith fluctuates when i overclock the mem from pc3200 to pc40000memmory instead of the bandwith getting higher it gets lower but only in memtest86 so what i wanted to know was are these numbers the bandwith? and should i tweak for higher bandwith or frequency?
Also do you know what the turbo option in asus bios does
for some reason the bandwith in memtest 86 goes up fron 2231 to 2450 thats good i would guess but my sytem blue screens when the turbo feature is on, even when i was installing the os. when the turbo feature isnt on it works without any problems
I'm running corsair xms pro xtra low lattency 2-2-2-5
System Spec:
Asus P4c800-E
3.2e @3.8ghz
2X512 corsair xms pro 2-2-2-5
all in wonder 9800 pro
74gb raptor
audigy 2zs
klipsch ultra
I'd use Sisoftware's Sandra benchmark suit for the memory. It's a bit inconsistant so you'll want to run it several times.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
