i bought msi rx 570 4gb now my pc wont boot when gpu plug in with pci 8 pin power cable when i unplug the 8 pin from gpu the pc boot
i checked gpu on another pc but it still not work
the mechanic says that your gpu is short circuit....
now plzz help should it be faulty psu who caused this problem??
should i changed my psu???
should it be 8 pin pci connector problem or it may be shorted...
pc specs
i5 3rd gen
gigabyte h61 mobo
12gb ram
500gb+320gb hdd
msi armor rx 570 4gb
500 watt psu 80+bronze cobra
pc specs
i5 3rd gen
gigabyte h61 mobo
12gb ram
500gb+320gb hdd
