need help
andrew_mani
17
Anyone has any idea what s.m.a.r.t is? My mobo settings allows me to enable or disenable it but dosent tell what it can do.
G
Guest
Guest
Here's quantum's definition of S.M.A.R.T. :
"The S.M.A.R.T.1 Self-Monitoring, Analysis and Reporting Technology System was designed precisely with this approach in mind. By using S.M.A.R.T. technology, virtually any intelligent component or device within a computer can communicate its predicted reliability status to its user and system administrator to provide comprehensive protection that can prevent system downtime, productivity loss, and even the loss of valuable data.
Since user data is not always as easy to replace as hardware devices, most computer users will argue that their data is the most valuable element of their computer system. In recognizing the need to elevate the protection of user data, Quantum has pioneered the implementation of the S.M.A.R.T. System for hard disk drives.
Through the S.M.A.R.T. System, Quantum disk drives incorporate a suite of advanced diagnostics that monitor the internal operations of a drive and provide an early warning for many types of potential problems. If detected, the drive can be scheduled for replacement before the loss of data occurs. The result: higher productivity and increased security of data. "
G
Guest
Guest
Here's what it is doing, physically.
"The S.M.A.R.T. system for disk drives, illustrated in Figure 1, is designed to revolutionize overall system and data reliability. The system is comprised of software that resides both on the disk drive and on the host computer. The disk drive software monitors the internal performance of the motors, media, heads, and electronics of the drive, while the host software monitors the overall reliability status of the drive. The reliability status is determined through the analysis of the drive's internal performance level and the comparison of internal performance levels to predetermined threshold limits. "
machow
855
So, basically, S.M.A.R.T makes drives smarter. :smile:
Smart guys are not smart; they only see things in different perspective.
1st <b>member</b>!
