Need info on Radeon HD5450 Silence 1 GB
lesac
Hey guys Ive done plenty of searching and i think ive found most of what I need, but basically I bought this Acer AX3400G U4802 super cheap, and I know cheaper isnt always better but I would like to know if I would be able to use this graphics card Radeon HD5450 silence 1GB with this computer?
I am only looking to run a game called VRC pro. which can be found here http://www.virtualrc.com/vrc-pro/start.aspx
Startup Operating System: Microsoft Windows 7 Home Premium 64-bit
Orientations Allowed: Vertical
Bays: 1 - 5.25" Drive Bay
1 - 3.5" Drive Bay
PCI Express X1 Slots (Total): 1
PCI Express X1 Slots (Available): 1
PCI Express X16 Slots (Total): 1
PCI Express X16 Slots (Available): 1
Memory Type: DDR3
Memory Slots (Total): 4
Memory Slots (Available): 2
Maximum Memory Supported: 8GB
Display Type: Monitor Not Included
PS/2 Connectors: 1 - Mouse
1 - Keyboard
LAN Ports: 1 - RJ-45 Ethernet Connector
USB Ports (Total): 9
eSATA Ports: 1
Audio Out Jacks: 5
Microphone Jacks: 1
VGA Ports: 1
Processor Brand: AMD
Processor Class: Athlon II X2
Processor Number: 255
Processor Speed: 3.1GHz
Processors Supported: 1
Processors Onboard: 1
Hard Drives Included: 1
Interface: SATA
Capacity: 1TB
Hard Drive Types: Hard Disk Drive
Speed: Variable
Optical Drives Included: 1
Optical Drive Class: DVD-ROM
Supplemental Media Type: Media Reader
Capacity: Multi-in-one
Media Types: Secure Digital (SD)
xD Picture Card
Reduced size MultimediaCard
CF+ MicroDrive
Compact Flash Il
Compact Flash I
MultiMediaCard (MMC)
Memory Stick (MS)
Memory Stick Pro (MS-Pro)
Audio Description: Integrated Audio
Audio Chipset: High Definition Audio
Channels: 5.1
Graphics Description: Integrated Graphics
GPU/VPU: NVIDIA GeForce 9200
LAN Data Transfer Rate: 10/100/1000Mbps
LAN Description: Gigabit Ethernet
LAN Interface Type: RJ-45
LAN Ports: 1
Power: 220 Watt
Mouse Type: Optical
Connection Type: PS/2 Mouse
Keyboard Type: Standard
Connection Type: PS/2 Keyboard
Height: 14"
Width: 7"
Depth: 20"
I have basic computer knowledge but dont know much. Will I need anything else or would I be good to go just adding a new graphics card (and maybe power supply)?
Thanks in advance!!!
