Need Insight On My Choices And Overclocking Info
G
Guest
Guest
I've decided to build a mid-range gaming machine.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147105
http://www.newegg.com/Product/Product.aspx?Item=N82E16811994001
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231209
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131329
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102822
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
But my real questions are:
1. Can a 400W PSU run all of my selected hardware under SAFE conditions?
2. Can I overclock with only a 400W PSU? If so how far do you think I can overclock my GPU and CPU and still retain safe conditions?
Your PSU should be fine, and yes you can OC, probably as far as the CPU and GPU will allow. The Corsair 400cx is a high quality PSU and with 30A on the 12v rail I think you are pretty safe.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341012 $54.99 ($44.99 after $10.00 Mail-In Rebate)
OCZ StealthXStream OCZ500SXS 500W ATX12V / EPS12V Active PFC Power Supply - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.181196 Combo Price: $112.98
GIGABYTE GA-G31M-ES2L LGA 775 Intel G31 Micro ATX Intel Motherboard - Retail
Intel Pentium E5200 Wolfdale 2.5GHz LGA 775 65W Dual-Core Processor Model BX80571E5200 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835207006 $29.99 ($19.99 after $10.00 Mail-In Rebate)
Sunbeam CR-CCTF92-4 92mm Core-Contact Freezer CPU Cooler W/TX-2 - Retail
