Question Need MOB suggestion for AMD 5600G using build components listed
welchs101
474
Hi, I am struggling to find a good MOB for my build. I have found a few i wanted but then i either lose out because they are out of stock or wont ship until like January or something. Note: I have ordered the following components for my build. Note: This build was put together with the help of a very kind person on this platform...not sure i can say their name otherwise i would. Anyway, thanks to them for their help.
Requirements/would likes:
I need a board that supports at least 2 M.2 type storage (see build below)
I would like (but is not a deal breaker...not sure if will need) a board that can output to 2 monitors
I prefer a board that does not cost more than $200..i was hoping for around $150 but i think that is not going to happen.....so i budget around $200.
i would like the board to be able to ship sooner rather than later so i can put it together before the holidays...i know i should have done this earlier but i did not know i was going to do this until just a wk or so ago.
I have been looking and i did find these two boards but i am not sure if they will work with my build components i have thus far. Especially the M.2 storage devices i selected (see below build). I am not sure if there are just as good a board but cheaper somewhere else.....also do not know if these will support my RAM......you get the idea i just dont know.
Amazon.com: GIGABYTE B550 AORUS PRO AC (AM4 AMD/B550/ATX/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 2/Intel Dual Band 802.11AC WiFi/2.5 GbE LAN/PCIe 4.0/RGB Fusion 2.0/DDR4/Gaming Motherboard) : Everything Else
ASUS ROG STRIX B550-F GAMING AM4 ATX Motherboard - Newegg.com
I ordered the following components already:
https://pcpartpicker.com/list/ZmHN78
CPU:AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor
CPU Cooler:Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler
Memory : G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory
Storage (1): Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Storage (2): Western Digital Black SN770 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Case: Fractal Design Focus 2 ATX Mid Tower Case
Power Supply: Rosewill Capstone 550 W 80+ Gold Certified Semi-modular ATX Power Supply
welchs101
474
Question: Is it better to have onboard (ie...on MOB) wifi or to buy something that plugs into MOB on the back for a wifi?
Also, i am suprised no one has offered any suggestions........have i done something wrong or violated some unspoken rule? I tried to make sure i put this into the right "section" which is under Mother boards.
logainofhades
I added my pick, to your list. I have the non AX version. I would have preferred the AX version, but Microcente had an open box deal that was too good to pass up, and I got it, and a PCI-E adapter, for less.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor ($110.16 @ Amazon)
CPU Cooler: Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler ($19.89 @ Amazon)
Motherboard: Gigabyte B550 AORUS ELITE AX V2 ATX AM4 Motherboard ($149.99 @ Newegg)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($84.99 @ Newegg)
Storage: Western Digital Black SN770 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($49.99 @ Amazon)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($88.98 @ Amazon)
Case: Fractal Design Focus 2 ATX Mid Tower Case ($60.98 @ Newegg)
Power Supply: Rosewill Capstone 550 W 80+ Gold Certified Semi-modular ATX Power Supply ($39.99 @ Newegg)
Total: $604.97
Generated by PCPartPicker 2022-11-30 15:42 EST-0500
welchs101
474
how did you find this........i was looking for one that had wifi plus two video outputs!!!!!!!! Hey two questions...........does it support these two M.2 that i want to put into board
want to make sure i pick a board they will fit into. Also, i have ddr4-3600.......does it also suppor this?
thanks!
