Need MOBO and Case
QwerkyPengwen
Splendid
Ambassador
Here is the build I am considering but without a case and without a MOBO.
My other build consisted of an ASUS MAXIMUS VIII HERO MOBO and a HAF X case for future upgrades/additions but I'd like to know what my options are for a less expensive mobo that'll support a single GPU (preferably support for 2 GPU's for adding one in the future) and has a decent rated ability to OC and I would like a case that will fit everything with a little room for putting in a custom loop and has a good overall airflow rating. I don't need nor want feedback on having different components than the ones selected, I just need to know what my options are with these currently selected components and all suggestions will be reviewed and the more options I have to look at the better so give me what you got. I would also like the price to top out at $1500 (that's including taxes and shipping WITHOUT rebates and discounts) but if it absolutely must go over because there is no other way to get what I want without doing so then I will allow a wiggle room of $100.
P.S.- And before anyone says something about needing to have a higher watt PSU for adding a second card I fully understand that I would need to upgrade to something like 1000W just to be on the safe side. Especially with adding other things like fans and LED's to the system
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($248.89 @ OutletPC)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.50 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory ($69.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($148.88 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card ($676.98 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ NCIX US)
Total: $1309.12
Generated by PCPartPicker 2016-02-16 13:55 EST-0500
I like the look of the Riing edition of the thermaltake core v51 with it's green color scheme. (especially since I'm going to be using nvidia graphics and all) I'll consider the motherboard.
Thanks for the input :)
